mikemolang
Chicago Coin Pro Basketball - Burned Out Flash-o-matic - Need wiring help
Well, THERE'S your problem! (see pics)
There are two large burn holes on the Flash-o-matic PCB. My plan is to take brass screws, grind the heads down to suit, and fasten them to the PCB with nuts. (OK, it may take a little more to keep them perfectly aligned, but you get the idea.)
The wiring for the one contact is obvious, and is still in place. However, I see no witness marks telling me what the second contact was wired to, and I know that without a path for current to flow, an unwired (or non-existent) contact would not have burned.
Help, please... Does someone have a photo (or a schem) that they are willing to share?
Thanks!
Mike
Thanks!
Mike
