Cherry Master Slot Machine help
Bigbill55
Donor 2013
Minnesota
Here is my headache:
I have a Cherry Master Slot. Haven't powered it up in over a year. Bring it in, let it warm up, works fine, except I only get the green on the display. I check the connections, clean the pins on the edge connector, same issue. I find a used monitor for $20 bucks. I go get it, see it it operation, colors are good. Plug it into the slot, only get green to show. I dig thru my pile of junk, find my RGB to VGA converter board, put that in, hook it up to a LCD screen I have (doesn't fit the slot), and all I get is green. The only thing I haven't tried is checking the wiring from the edge connector to the monitor.
Any ideas would be appreciated. Thanks,
Bill
Bill
You get sound effects etc!? Playing blind?
If not sounds like battery on board died possible corrupt safe ram
