As far as I know there is not a wiring diagram, but you should be able to work out the wiring with the pin outs. (from Sarge77's Link)
=============CHERRY MASTER PINOUT===============
PARTS SOLDER
VIDEO RED 1|1 VIDEO GREEN
VIDEO BLUE 2|2 SYNC
SPEAKER 3|3 GRD
4|4
5|5
6|6
7|7
COIN SW. 8|8
ADJUSTMENT
PLAYER START SW. 9|9
PLAYER SMALL SW. 10|10
PLAYER BET SW. 11|11
PLAYER TAKE SCORE SW. 12|12
PLAYER DLB. UP SW. 13|13
14|14
15|15
PLAYER BIG SW. 16|16
17|17
COIN SW. A 18|18
KEY IN SW.
COIN SW. B 19|19
COIN SW. C
BOOKS SW. 20|20
TEST SW.
PAYOUT SW. 21|21
KEY OUT SW.
HOPPER COIN FULL SW. 22|22
HOPPER COIN SW.
COIN A COUNTER 23|23
LOCKOUT COIL A
KEY IN COUNTER 24|24
COIN B COUNTER 25|25
LOCKOUT COIL B
COIN C COUNTER 26|26
LOCKOUT COIL C
HOPPER COUNTER 27|27
COUNTER (LACK OF CHIP)
KEY COUNTER 28|28
START LAMP 29|29
PLAYER BIG\SMALL LAMP 30|30
PLAYER BET LAMP 31|31
PLAYER TAKE SCORE LAMP 32|32
PLAYER W-UP\BET LAMP 33|33
34|34
35|35
GRD 36|36 GRD
(20 Pin Power Harness not shown)
The things highlighted above in
RED are connections you will probably not need to make. The Books, Test, and Payout Sw (
gold) might be worth finding a space for if you have spare switches inside your game - its up to you.
From there, its finding a spot for the buttons (
blue) on your JAMMA harness. The JAMMA standard gives you eight buttons - one start and three action (A/B/C) for each player. You could easily use the following:
Player 1 "A" = Start
Player 1 "B" = Bet
Player 1 "C" = Take Score
Player 2 "A" = Double Up
Player 2 "B" = Big
Player 2 "C" = Small
You could also use the Player 1 "Start" button and the Player 2 "Start" button for something like this:
Player 1 "START" = Start
Player 2 "START" = Bet
Player 1 "A" = Take Score
Player 1 "B" = Double Up
Player 2 "A" = Big
Player 2 "B" = Small
Those are just 2 options - you could come up with several more on your own.
It really comes down to are you wanting to use your JAMMA game to test you PCB or make a fully functioning Cherry Master. The problem is that JAMMA does not support lighted buttons (
purple). If you are going to use lighted buttons, it would be safest to avoid placing those on the JAMMA adaptor - especially if you want to keep the joysticks for other games. You do not want to accidently put a steady 5V into one of your JAMMA games if you wire the lighted buttons to say where the joysticks are on a JAMMA harness - you could fry something.
EDIT - just looked at your adaptor pic and it does not even have the wires for the lighted buttons so nevermind.
If you need the JAMMA pinout:
http://www.jammaboards.com/jcenter_jamma_pinout.html
(except he calls the Player 1/2 Action Buttons "Button 1" "Button 2" and "Button 3" whereas I said "A" "B" and "C")
