Cherry Master dip switch help needed, Please
dave2236
Green Bay, Wisconsin
ok, I need help with an original Cherry Master board, dip switch settings to get the game on $1 = 100 credits. I don't understand the combination I need to get. I keep getting either 4, 8, or 40 credits for $1
DIP SWITCH 3 1 2 3 4 5 6 7 8
A B
K 1-10 1-5 + +
E 1-20 1-10 - +
Y 1-50 1-25 + -
1-100 1-50 - -
slots 3/4
I 1-1 + +
N 1-2 - +
1-5 + -
1-10 - -
___________________________________
slots 5 and 6
C D
R 1-5 1-2 + +
A 1-10 1-1 - +
T 1-25 2-1 + -
E 1-50 5-1 - -
slots 7 and 8
1-1 + +
1-2 - +
1-5 + -
1-10 _ _
____________________________________
http://www.coinop.org/kb_dl.aspx/KB/gametech/cherrymasterpinouts.html
http://www.j-h-amusement.com/secure/uploads/file/Cherry Master.pdf
DIP SWITCH 2 1 2 3 4 5 6 7 8
slot 7
KEY IN A TYPE -
TYPE B TYPE +
______________________________________
DIP SWITCH 4 1 2 3 4 5 6 7 8
slot 5
TYPE OF C TYPE +
COIN D D TYPE -
any help would be greatly appreciated. Thank you very much, Dave
i suspect that you'll have to rewire your coin acceptor to "key in" to get the 100 credits per coin, but thats only a guess.
turn the power off.
set dip switch 2 position 7 to off.
set dip switch 3 position 1 to on
set dip switch 3 position 2 to on
turn power on.
then touch the "key in" (pin 18 - solder side) to ground. (pin 36 either side).
In theory, that should add 100 credits.
