Tighe
Yeah, this is very helpful! My mulit-meter manual didn't go into any specifics about when to use certain settings and I don't even have a basic understanding of this stuff.
I just googled using a multi-meter and it says and good example of DC power is a battery, and a good examplbe of AC power is current from the wall. So, based on that, you might think you'd be measuring boards using the AC settings. I'm assuming this isn't the case though because the transformer changes the AC power from the wall to DC, and that's why Tighe is measuring DC power?
I had no clue on the sub settings, but after Ian's post that makes perfect sense. He's looking to measure 5v so he's selecting the smallest setting that covers the range he's looking for (you'd need headroom in the setting in case you're a little over.) If there was a 10v setting he'd want that but he wouldn't use a 5v setting because his reading might be 5.1v.
The other thing I could never figure out is where to take the reading off the board. I've heard of posts, caps, chips, edge connector, etc. It would seem like the cap is the easiest since there's only two places to test from, making trial and error a two step process. I guess that's just the reading on that one cap, but if you're trying to tell whether your power supply is giving off 5v instead of trying to troubleshoot the board it would seem like a cap is a good place to check.
Great post. Thanks.
Oh yeah, Ian is right on there being no edge connector on the 4-board DK set. I've got the 4 and 2 board stacks and the edge connector is only on the 2-board version.
AC stands for alternating current, and what that means is that there is no positive or negative, the current alternates polarity 60 times a second or 60hz. There are a lot of advantages to AC, there is much less resistance when transmitting power, and the 60hz can be used to control motor speed, and timing. But you can't build any logic circuits with AC.
So power supplies in electronics use what is called a bridge rectifier to convert ac current to dc. But before that the ac is used to energize a transformer which is two coils together the ratio of loops in each coil determines the output voltage. The input coil when energized makes an electro magnetic field. The other coil if then energized by the field.
The bridge rectifier then receives the stepped down ac voltage 12v AC and the converts it to 12v DC. The bridge rectifier is a very simple device that contains 4 diodes. Diodes only let current flow in one direction which is a pain to describe, but simple when represented in a graphic:
http://upload.wikimedia.org/wikipedia/commons/2/2c/Diode_bridge_alt_1.svg
