Chassis swap?
Some 7600 and 7900 series may have a 22.5mm diameter (8 pin) neck and others may have a 29mm diameter (10 pin) neck.
all the 19" K7000's have had of any series have had the small (8 pin) neck, but i've heard tale of the 10 pin neck variety.
if the neck pinouts match (10 pin) and you swap the yoke as well as the chassis, it should work.
