Chassis swap question
Burt6666
Calgary, Alberta, Canada
I have an Arkanoid cocktail with a 19" Shinlee monitor in it.I have a working G07 and WG 19k4701 chassis here.Can I swap one of them in or do I have to change the tube as well?Tube is a Philips 19VKUP22.
well if you just want to swap the chassis , I would say its a no go , but if you swap the yoke and chassis , if the pin config is same as the neck board then no problem. tube , unless the pinout is different , makes no real difference
Yeah,was hoping to just swap the chassis because the tube is mounted really weird and there really isn't much info on these shinlee monitors.I have lots of caps here but not sure what to change.
I have had a couple Shinlee monitors, never had to work on them , you could ohm out the yoke on the shin and see if it is close to the GO7 or the WG, if they are , you could try a swap then. the 4701 I am not sure on resolution with that one
