cascadecomic
This coming weekend I will be replacing my first monitor chassis and I have a couple of basic noob questions. Once the tube has been discharged how do you remove the suction cup piece from the monitor? I assume there is some sort of clip in there just not sure if it will be obvious when I start or not. Also how do I remove the small board from the back of the yoke? Screws, clips, does it just pull off? Thanks.
