Chassis Board Switch
GrimJack0
Pennsylvania
Is it possible to switch from a WG 25K7197 to a Hantarex chassis board? Are the chassis and neck boards interchangeable?
You would have to swap the yoke from each monitor also in order to work properly. That would involve doing a full convergence procedure. Of course this also assumes the purity rings and yoke don't have their clamping "tabs" break off from old age/heat failure. Then you're screwed.
