Thanks blkdog7,
So when you say:
"Doesn't work well in a 4 slot. Can't switch to other carts without modding"
That it does work in the 4 slot right? And if you want to switch you need to add that wire for the select button?? Or by not well you mean that it glitches?
What is concering me is that the 4 slots are all non-JAMMA, even the 2 and 6 slot. Only the more recent 1 slots are JAMMA. So this cart will plug into both?!?!
I don't care so much about load time, I just want it to work. And it would be nice to have Last Blade 1 which is only in the 138.
The 138 in 1 works fine in the 4 slot. It works with the 4 slot harness. I have an original factory dedicated NEO 4 slot. No problems except you can't switch to the other carts without modding the inline harness. I had to leave all the other slots empty to get it to work!
