Changing B+ on Sanyo.
thefader
South Dakota
So I got new fuses. I measured both of my monitors that have the droop on the left side : 90V. I put my little electronics screw driver in the B ADJ thing and turned it slowly both ways.. No change. The first monitor I did, the little top piece came off. But its still just at 90 V. What am I Doing wrong, I turned it a full rotation, and still 90 V.
So I guess my question is, Can I install new B+ Pots, was I adjusting it correctly, but It was just shot? and how do I do this?
You can install new pots, but if the B+ is not adjustable above 90v, that usually means a bad flyback.
Ok. One of the B+ adj broke completely, and the other I spun about 180 degrees and no voltage change. Where would I get new B+ Adj pots, and a flyback?
