changing a yoke?
xads308
Michigan
hello, i burnt out the yoke on my monitor a while back, and i found the yoke i need on ebay (electrohome G07). is it easy to change a yoke? how do i change a yoke? on the seller's ad, it said that the yoke may need adjustment after installation. how do i adjust the yoke? is it really necessary?
If you buy JUST the yoke and the purity rings aren't attached to it, or aligned with it and marked, then you'll have to do a convergence from scratch. It's absolutely necessary, as the picture will be terrible. It would actually be easier to get another G07 with heavy burn, but a good yoke..Find a fat neck CR23 pinout tube, mark the alignment of the yoke and rings on the crap monitor, remove the yoke from the donor tv tube, transfer that aligned stuff to the donor, should be much less work that way.
