Change Time VM-010 changer fuse size?
Parzval
Donor 7 years: 2017, 2020-2025
Pottstown, Pennsylvania
I picked up a VM-010 changer and it's missing it's fuse. The manual doesn't say what size it takes. Anyone have one they can check and see? Appreciate it!
Thanks!
Josh
Thanks Ken. I was going to try a 1 amp. It takes a 5x20 mm, and I only had a 5x15 mm. In fact that was the only small fuse I had at all. I tried it anyway but it didn't make contact. I ordered a kit when it arrives I will try a 1 amp and see what happens. If it doesn't blow we're golden. If it does, I don't want to keep trying larger and larger fuses.... So if anyone that has one could chime in it would be appreciated.
