FS Parts: Championship Sprint Control Panel and Marquee
Vongoosewink
Indiana
I'm in the process of switching my Championship Sprint over to a Paperboy, so I don't need the control panel and marquee anymore.
The CP is in good shape, it has a few blemishes and dents but looks great installed -- see picture. There is a small crack up at the top above the left steering wheel, but this is covered by the metal bracket that holds the bezel glass on, and is structurally sound. The wheels & harness are included, they work smooth and look great. Should be plug & play if you have a machine already. Price is $60 plus actual cost of UPS ground shipping (likely around $20-25, it is big and heavy.)
Also have a marquee, it looks nice and is not badly faded like many you see. Has a few scuffs, but these are under the part covered by the brackets, so you can't see them. $25 shipped, or add to the CP for just $20.
attachment.php
attachment.php
These cabinets were made to swap between the System II games.
Look inside. There should be a place inside the back of the cabinet, opposite side of the door hinges where you can screw your Championship Sprint control panel in place for storage.
Then when you get the urge to swap back, you won't have to locate another control panel.
Also, what about the gas pedals?
I left my pedals in place and now people wonder how they're supposed to control the bicycle with them..
You are the dude! I did not know that... I went down and opened up the back of the game, and looked inside...
attachment.php
After a bit of looking, I found the metal brace in the bottom of the cabinet, just lying there. I wonder if this has been used/converted before? Why else would someone unscrew the brace from the wall?
So I bolted it onto the control panel and gave it a try:
attachment.php
So awesome! It is not an exact fit, so I'm wondering if I got the bolt/attachment to the CP just right... also, I found 2 little metal braces inside, are these part of the attachment?
attachment.php
Thanks again, Kstillin, rep for you!
This stuff is still available!
Who likes Championship Sprint? Let's make a deal, I don't need this stuff!
What is a fair price for a semi beat up Championship Sprint? It works fine, but is missing the control panel latches and the plexiglass is pretty beat. I figured since some of you are owners you'd know best.
