CGA/VGA converter issues?
brzezicki
Maryland
Hello, I've got one of those CGA/VGA converters that I am trying to use on my test bench.
(the ones that look like this
http://www.jammaboards.com/store/im...8220_WM_480x484_LR13317346504f60a87a5c3ab.jpg
problem is about 1/2 of my boards when I use the converter will have a corrupted frozen screen. The game is playing but it's like the video display board is confused (sync issues?) and the screen is often frozen and usually garbled.
I konw the boards works fine, as if I pop them on a normal CGA monitor no problems.
wondering if this is maybe a bad board or if this is a common issue for those converter boards.
-thanks
brian
You've got one of the old ones with the bad firmware. I had the same issue. I bought one from Jammaboards and it works great. Haven't met a board it won't work with yet. Unfortunately, you'll have to get a new one...
http://www.jammaboards.com/store/cga-ega-yuv-to-vga-arcade-hd-converter-pcb-gbs-8220-gbs-8220.html
Or if you're more comfortable using Ebay, here is the same converter via jammaboards.com's Ebay account...
http://www.ebay.com/itm/GBS-8220-RG...011?pt=LH_DefaultDomain_0&hash=item1c2a3389f3
Yeah tried that just got a new frozen screen.
Ordered a new board from Jamma boards hopefully will arrive soon.
Should have bought from there to start previous board was an eBay cheaply.
I also am having this problem with a Centipede conversion. I have the green boards. I've had these boards for over a year and now all 3 of them having the same issue. Ugh can I use these older boards in anything else then since I'll have to buy the new style?
