cga to vga conversion issues
pinnut
New York
i have a data east astro fighter. the 13 " cga monitor is shot. finding a replacement is tough, its a cocktail and needs a very narrow chassis to fit. i have a vga flat screen that will fit nicely. problem is, with one of those ebay chinese cga to vga converters, the image is shaky when used with a flat screen. it is also shaky with a vga crt . i hook the game right up to a large cga monitor, all is fine. its there a work around? a better convertor?
thanks
Adjust the clamp settings.
using the correct sync wires? I know on the converter, I've only used the grey sync wire and not the yellow one.
what are the clamp settings ?
thanks
You may have different numbers needed in the settings, as this is an EGA video machine in the video
im using the grey wire. i found the clamp settings, no help. ive tried every setting i could find.
Plug another VGA cable into the "VGA Input" connection as a dummy. That will stop the shaking.
plugging in the added cable helped a lot , cut out 90% of the jitter. however, rebooting the game brought all the jitter back, and cant get rid of it, even with the added cable
thanks
like a schmuck, the second time the spare cable was plugged into a spare board next to the one being used. its now back to 90% better.
You adjust the holds? Can you post a video? You may need to add an 8k-10k ohm resistor onto the sync wire.
I just went through this BS with a golden tee. Set your top clamp at 3 and your bottom At 4 and then press the auto adjust button on the converter. It worked for me
a 4.7 k resistor inline with the horz sync is working so far.
