CGA/EGA to VGA - missing something
jetusenet
Donor 4 years: 2011, 2013-2014, 2024
Staten Island, New York
Hi;
I have a Neotec 500DX which works great in CGA/EGA mode but I tried to use it in VGA mode and it's not getting the signal properly, no display.
I tested the signal with an LCD and it does work properly so that it not the issue.
There is no manual, per-se but I tried to follow the schematics and there is a switch (SW1) which would switch the sync from Comp to H/V but I am not sure if I should switch it or not, I do not want to damage anything.
What I did already was:
-swap the little plug leading from the neck PCB from the CGA/EGA receptacle (W102) to the VGA receptacle (W106).
-removed the CGA/EGA input plug from W101
-attached the VGA cable to W103
I searched the main PCB for a switch but cannot find one!
The only two jumpers that I see are on the interface PCB, listed as SW1 and SW2. SW1 right now is jumpered for comp sync and the other option is H/V.
SW2 is jumpered for comp but there is no other option listed, so it would be "open" if I changed the setting.
ANY help would be greatly appreciated.
Thank you in advance
Jeff
OK, I went over the schems again and took a chance........and.........I got game!
I switched the SW1 setting from comp to H/V and I'm good to go.
Hopefully this will help someone in the future.
Jeff
