I've only ever worked on a couple Ceronix monitors.....they were both VGA/high resolution monitors. I don't recall their numbers. Do you know what resolution those you have are?
3) The last one I had to work on came out of a slot machine, and required 220vac to work. I had to use an Atari power brick backwards to get the proper voltage for testing.
They didn't come with any info so I wasn't sure if I could use them or not.I'll take look at link and see if I can figure anything out.I was hoping to put one in a Tron ct I just picked up. Thanks for the info.
