As noted earlier, touch base with @DLPHere's what I'm using it for, a 3d model I'm working on for 3dArcade. I'd love to do the whole range of the woodgrain Centuri games, but artwork, or even decent photos, of the rarer games - Roundup, Challenger, D-Day, Locomotion, Route 66 - is just impossible to find.
The only thing that is missing would just be solid blue, none of the graphic is missing. If for a 3d model, here is the original uncropped photoIt doesn't look like too much is cropped off, I should be able to recreate the little bit that's missing. Thanks guys!
Not sure what you mean, I don't see any areas of solid blue missing. There was a little clipped from the sides but it was negligible. The only thing I would have incorporated but it would have been a pain to do is where the red stripe overprints the blues, it's not completely opaque on the actual cp and you can see the red darkened a little over the blue.The only thing that is missing would just be solid blue, none of the graphic is missing. If for a 3d model, here is the original uncropped photoshould be able to crop it yourself if that works.
I will definitely have to do that. And that row of cabinets is just staggering!As noted earlier, touch base with @DLP
If you missed his Centuri Row of the Gods: https://forums.arcade-museum.com/threads/meet-the-centurion-army.542769/
All of them? I have a Monroe stick modeled for my Time Pilot, but I've seen pretty much a 50/50 split in all the photos I've collected between Monroe and Wico, so I went by the flyer photo which is a red-top Wico.@jibmums I'll also put in that The Pit came with a 4 way Monroe instead of a 4 way skinny wico, black top
I was talking about the dark blue.All of them? I have a Monroe stick modeled for my Time Pilot, but I've seen pretty much a 50/50 split in all the photos I've collected between Monroe and Wico, so I went by the flyer photo which is a red-top Wico.
Interestingly, I've also seen three different arrays of carriage bolts at the top edge of the cp: a four-bolter, a three bolter, and a three bolter with the two outer bolts a little further inward. I went with the three bolter that was more similar to the other Centuris I already had done.
Would the red Wico stick be totally incorrect for all Pits? I kind of like the way it matches the red buttons, but I'm a stickler for authenticity.
When these arcade games hit the floor, it was a free for all to how to maintain them and then factories started to follow. Factories also used parts from other machines, made on the spot modifications, etc.
