You are using an out of date browser. It may not display this or other websites correctly. You should upgrade or use an alternative browser.
Museum of the Game® & International Arcade Museum® Forums
1. Is the cabinet in the front open underneath the coin box with a gap that would allow you to see the PCB if you laid on the floor and looked under? Or am I missing a piece?
2. Who has new marquees produced like the originals? Everyone I find is all roached out just like the one I have on it.
3. Anybody know if anybody reproduced the plexi and the cardboard bezels? (typical scratches of peoples names in the plexi and the cardboard has tears) I could make my own cardboard but I would prefer to save the time and buy a repro already done. Also thought about trying to buff out the plexi but that always goes bad. Other thought was to try and turn it around and see how bad the scratches show
4. Is there a volume pod on the board? I assumed there was but the machine I got someone taped over cardboard and foam over the speaker apparently to muffle the sound. I haven't pull the back door off yet but I assume that was to try and deafen the sound so it wasn't so loud, any other reason someone would do this?
5. I need to replace the T Molding and it appears to have a thicker edge to it on the outside than on the inside? Is this a special T Molding they used on these games? It also appears wide, I haven't measured it yet so if someone already knows the size and can throw that at me you will save me the time from going to storage to find this out.
