I have a Centipede that has a trackball that isn't quite right. When I push it up, it will sometimes go up but then it goes right back down again. I have to spin it pretty well for it to go up but then, while it is spinning, it will go back down on its own. Left and right movements are fine.
Things I have done:
Put in new rollers and bearings
tried two different sets of optic boards (same result for both)
Swapped out the metal wheels
Dave (ArcRevival) told me to check the edge connector and I wiggled it but didn't see any differences. That is the extent of testing the edge connector up to this point, as I need to get the lock open on the back.
Just wanted to see if anyone had any ideas or have seen this issue before.
Thanks,
Torin
Things I have done:
Thanks,
Torin
