Centipede sound issue..
Muerto
Invisible, smoke, Denmark
suddenly the other day when i was playing a game of centipede, the sound died, today i had some time to take a closer look....
when i turned it on, and pressed 1 player, there vas a very very faint sound wich died 2 sec later but if i turn the volume up to max, i can hear the sound very very (VERY) faint..
is there sonthing wrong with the AUX/Audio board or the "knob" wich controls the volume level?
Your "knob" is probably OK. Check voltages on the Audio/Regulator board. If all voltages are present....I'd start with one of the TDA2002 on the A/R board...or the LM324 on the motherboard.
Edward
.... wich is the TDA2002?
ok, found them! (im pretty green at this!)
Im not sure what the voltage should be, but when i try to messure the voltage on Q5 and Q7, the speaker humms like crazy...
do you know what the voltages should be?
Just use the test points on the A/R board.....The ones for the audio are 12VDC, -5VDC, and the 10.3VDC.
Edward
ok, there´s somthing serious wrong here!!!
12VDC reads 12
-5VDC reads -2
10.3VDC reads 13
where can i ajust that?
That's probably the problem. The -5VDC regulator is shot. 13VDC on the 10.3VDC rail is fine. That line is unregulated....and almost always reads high.
Replace Q9 (LM7905) on the A/R board and report back.
Edward
