Centipede Serial Number
Muffindude
Richmond, BC
I was looking at the back of my Centipede, and I noticed that the sticker with the Serial number was ripped off. Is there anywhere else that I could check for it?
It was converted, and the only original pieces are the monitor and the power brick.
Thanks in advance.
Check the power brick and the monitor for a little silver sticker. You might even have one on the coin door. Atari stuck them in quite a few places. Your serial number will start with UR.
No way a guarantee, but more than likely the power brick is original to the cabinet. I bet AR2 boards got swapped around quite a bit in the field, but power bricks, not as likely. The power brick should have the serial decal on it.
Thanks for the replies.
I was dusting out the machine, as there was a ton of dust, and came across a number on the power brick, then I found the same number on the piece of wood that supports the monitor frame. So I reckon that's the serial number. Looks to be #2245. Don't think I saw any silver stickers other than on the back.
Here is an example of the Atari serial stickers on my Tempest. They stuck them everywhere.....
Centipede may not have them. My Centipede was heavily converted when I got it. All it had left was the big serial sticker on the back.
