Centipede RAM errors
Level42
Ridderkerk, ZH, Netherlands
Got a Centipede board that gives 3 beeps in test-mode. The lower half of the screen gives a lot of H-es, fire bullets are wrong but I can start a game and play. Sound is fine.
3 beeps indicates bad RAM 2101 at K7. Socketed and replaced it, still same problem.
Tried a 2nd 2101 still same problem.
Tried swapping the Pokey with my known good one, still same problem.
Any ideas ? Mux ?
Recheck your work. You probably broke a trace while swapping RAMs. 3/4 beeps is the correct number of beeps, given that display.
Probably not a bad write signal, since that would effect 2 RAMs, and the garbage would be more random.
