Centipede picture
Stuffmonger
California
Ok, so today, i discovered I'm a dumbass, and got my centipede working. The only thing that I needed to do (circuitry-wise) was wire the video from some cut wires I neglected to see before. So, I did. Apparently, the original centipede monitor had a split sync, but the monitor I have in there has composite or horizontal only (I'm not 100% sure). I hooked it up to the colors, ground, and the horizontal up to the sync, and got a steady picture. The picture is dark though, and hard to get it to steady out perfectly. I'm not sure if this has anything to do with the fact that I have a jamma connector also hooked up to the same monitor (no board on the jamma harness), or if it's just due to the monitor settings. I left the vertical sync disconnected from the main board. The monitor was nice and bright/great colors when it was running straight jamma (before I hooked the centipede back up to it). I have not tried to run jamma in it since putting pede back in. Any ideas or thoughts? I will be sure to post a restoration thread with before and after pics when all is done.
