centipede monitor support needed
VMAXMADNESS
Corning, New York
I'm in need of a centipede monitor support (the piece of wood that the monitor is attached to) or a picture with measurements of it.
thanks
Randy
Well, I don't have one handy, but the opening is just a tiny bit wider than the outside edge of a horizontal shelf-mount frame with a slot on the right side top and bottom for the bottom frame flange to slide in. Then there are two bolts mounted above for the top side flange to slip onto, and two holes on the bottom for bolts/nuts to slip through to hold the bottom side flange in. There is a piece of wood inside below the frame for the bottom flange to screw to as added support.
Perhaps that will help you visualize a way to make one...
I literally just came in from removing my centipede monitor. I'll go back out and grab the measurements.
-Jim
The opening is 14.5 inches wide by 18.75 inches tall. It's basically just big enough for the chassis to fit through.
There's about an inch of wood showing top and bottom past the braces above and below the opening. Note that on the right side, it's notched out to the width between the braces (to allow the bottom/side of the chassis to slide in).
Was that what you were looking for?
-Jim
