partygt Active member Joined Apr 5, 2009 Messages 4,122 Reaction score 19 Location California Sep 16, 2010 #1 got a centipede that keeps blowing the fuse on the power block maked f1 slo blow fuse screen goes white replace the fuse works again for a few min then blow again? any help would be greatly apreciated. [email protected] thanks
Dokert Well-known member VAPS Joined Jun 3, 2007 Messages 12,751 Reaction score 141 Location Arlington, Washington Sep 16, 2010 #2 Sounds like a bad line filter, or someone has jacked up the AC wiring.
OP OP partygt Active member Joined Apr 5, 2009 Messages 4,122 Reaction score 19 Location California Sep 17, 2010 #3 centi fix where is the line filter how do i check it? all wiring looks pretty clean. thx Paul
Dokert Well-known member VAPS Joined Jun 3, 2007 Messages 12,751 Reaction score 141 Location Arlington, Washington Sep 17, 2010 #4 Line filter is the silver box that the power cord runs through. IIRC you will have to pull the power brick and flip it over to find the line filter.
