Centipede garbage on screen
chips4sle
Spring Grove, Illinois
Ok
I have a centipede board I'm working on
I've replaced all the 2101 ram as 4 of the 8 tested bad
Also replaced the 2114 to be safe
When I press the test button I still get random 4 or 6 beeps for ram error
And the screen does this with static on it as well
The screen is white the dark is just from the camera
RAM errors when you know the indicated chips are good typically means either a bus issue, or a decoding logic issue.
Check for shorts between bus lines, for all busses, to start. But it could be a bad buffer, or decoder logic chip.
Also make sure all of your clock signals are good, as well as the CPU. Start with the simple things.
