socalarcade
title says it all i have tested the board in a jamma cabinet and it works fine
I would check 2 things.....
#1 that the video input wire is making a good connection where it plugs into the chassis....
#2 with the monitor off, that the resistance on sync pot changes as you dial it up and down..
any ideas on how to fix the sync problem
Identify what version of Kortek monitor you have first.
1. So we can verify you have the sync correctly connected.
2. So we know what adjustments are available on that particular model.
it is a betson 19" and the chassis is a koetec KT2001 SF
there are 2 switches on the monitor chassis 1 says HS COM neg or pos setting and the other says VS neg or pos what setting should these be set on for centipede
