Centipede G07: Cap kit, flyback, HOT transistor Replaced. Red picture?
time4akshun
Parsippany, New Jersey
Hey guys,
So I did a full cap kit, flyback, HOT transistor, and 901 small fuse on my dead centipede GO7 and now have a picture back.
Only prob is, game still plays blind but with only red on screen?
Thoughts?
Time
Have you reflowed solder on every inch of the chassis? If not, do it now. Pay attention to any of the pads under header pins or where the rgb/sync is plugged in.. Don't forget to reflow the neck board. Make sure to test the 3 trannies on the neck, as 2 may be blown or have cracked pads making it red.. Also, check the solder under the pots and or meter the pots..
That should keep you busy.. :)
