Robotron Jon
I have a centipede cabaret with a rebuilt trackball. The game has intermittent problems with up and down control. Sometimes it does not allow you to control up and down movement - only side to side - and you slowly move up to the top. Other times, I turn on the game and it works fine. I had this same problem with this game before I swapped out PCBs and the problem went away for a while. Now it's back. I was thinking this might be a wiring harness problem rather than a PCB issue.
Thanks.
Thanks.
