Centipede cocktail
baggdexpo
Ohio
I have a hacked up harness in my new game with a crappy switcher and need to kno what does the start cone led light run off of power wise? Right now they have wires on them but are cut... Thanks
On my Millipede they run off of 5v. They are fed from the game PCB as they are steady or flash based on game function. You can download the pinout and it will tell you which pin on the edge connector feeds each cone. If you have the voltages correct going to the PCB from the power supply, and the PCB is working correctly, then the cones should work, I believe.
-scott
Thank you sir!!!! Now I have a project to work on tonight
