I just picked up a Centipede cabaret with a small problem. The screen has a very noticeable vertical shake to it. Its playable, but will give you a migrane eventually. Where should I start? Is this a common problem?
I got +12.13 and -5.10. Good or bad?
Cap kit is on the way. Is there anything else I can try/test in the meantime?
