Centipede Cabaret #1962
great start! IMO, you'll want to replace that ball and rollers, and possibly the bearings. You might be surprised how much smoother a new ball rolls compared to a worn one.
Indeed, shortly thereafter that post I actually ordered a rebuild kit to start from scratch. I'll likely be putting a new ball in too.
Power brick made over and completely reassembled with new filter cap from AP&R. Glad to have completed this very important portion of the restoration.
BEFORE:
AFTER:
Went with the same sapphire I used for the cardboard bezel because why not. Original stickers and fuse cover. Unfortunately, the serial sticker didn't make it, the number was just gone. I found I had some difficulties with regular blue painters tape covering the original stickers but they're still there at least. Next time I'll be sure to use frog tape. Otherwise, very happy with this one.
One of the more nerve wracking things I've ever done. And I've never laminated a cabinet before but I figured after seeing so much praise for the results and agreeing with that praise here and on YouTube, my first project consisted of white matte laminate and I actually think it really turned out nicely. Like I was holding my breath the whole time and I'd never used a router before but wow. It's coming together. Next comes Phoenix Arcade side art.
After this photo I went back and cleaned up the rough edges. What a difference from the garbage woodgrain.
Today was G07-CBO rebuild day and coin door paint strip/Evapo-Rust submersion start!
With the chassis having been hosed down with water and sprayed with Simple Green those many days ago, we have a pretty nice G07 canvas to work from.
Still working on replacing the B+ filter cap and the HOT. All other caps in and ready.
Our starting point for the coin door:
The paint was chipping on its own already so stripping the rest was really easy with some generic citrus paint stripper and some semi-paste stripper in conjunction:
Stripped and ready for a bath:
Now we'll sit overnight in preparation for a coat of acetone and paint!
That's it for today's log, steady progress piece by piece!
Today I'm very excited to have a fully laminated cabinet, fully painted coin door, and fully painted back door!
Began the day and pulled the doors from the Evapo-Rust bath. Like usual magic, they're basically brand new for painting. Love this stuff so much.
I did satin black for my Black Widow, this time I elected for a hammered black having seen some others with great results. Two coats on these after a wipe down with acetone.
Coin door frame on this one in much better shape than Widow. Just a Simple Green/hose bath, wipe down, and ready for hammered black to match the doors.
I went back to square one on the right side's bottom corner issues. All the old Bondo came right off and I re-evaluated. I'm not woodworking pro, this project is the first time I've literally ever done anything with wood whatsoever. But I have wood ready for my marquee light mod and decided I could effectively "rebuild" these corners, fill in the crack with Bondo more efficiently, and sand from there. It worked pretty well all things considered.
I drilled two wood screws into the transplant to the cabinet to keep them in place for Bondo. I then sawed excess to do my best to make the transplant flush with the cabinet. In this picture you can see it's not exactly level or flush. More sawing and sanding rectified that.
Bondo followed and I said audibly "good enough for government work" (IYKYK) and was ready to apply the laminate. This took a long time. I wanted to do my best to get it right, even if laminate is pretty forgiving by nature.
The end result is a fully laminated cabinet! You can see I have some flushing to do on the bottom but overall, I'm not complaining about it. Everything else is really sharp and applying the side art is really gonna make me cream, lemme tell ya.
I also painted the back door satin black and will need to smooth it a bit but it's also done too.
Next steps are to clean up all the miscellaneous coin door pieces and reassemble the completed coin door, restore the bucket assembly and test panel, and apply this side art! Moving along.
Yeah lmao, this was the first pass and I'll straighten them out, sand down the wood, etc.
Just a word of advice for the next one, get all your wood edges perfectly square and straight first. When everything is true, smooth and square, install the laminate. Trim the excess using a bottom bearing trim bit and router. The bearing rides the wood underneath and the blades above cut the laminate to the exact profile you have provided. It's a pretty much foolproof method, no edge sanding needed.
Hey guys. My first ever restoration project since entering the hobby and collecting games. Everything I've picked up has always been working for the past few years. That ended when I found Centipede cabaret 1962 in a barn for a hundred bucks, ashtray and all.
Non-working, monitor came up, everything died shortly thereafter. All things considered, this thing could've been in much worse shape. The fact anything happened at all at power up was a miracle in and of itself.
I've maintained and done general maintenance and repairs of my games of course, but never a full project.
So following my touching up and general refurbishment of the Out Run @KaBoom1701 graciously sold to me, and the Black Widow kickplate/coin door restoration I did after picking it up from @BigDogs, now's the time to turn my attention to Atari's second best selling juggernaut and one of my favorite games: Centipede.
I currently own an upright in great shape. At first I thought I'd take all its guts and move them over to the cabaret since that game is a mish mash of serial numbers and scrounged parts since '81 and they're like 30x more common than the cabaret.
I quickly decided against that after discovering the serial number integrity of Mr. Cabaret 1962. I don't quite know what I'll end up doing with my upright in the event I finish this project with satisfactory results. We'll cross that bridge when we get there.
So today began and I just went after it.
I quickly learned just how grimey, dusty, and filthy this woodgrain little brother was.
Here's a pic of the power brick shortly after a bit of WD-40 rust penetrant to unscrew it from the cabinet.
That'll be the first area of attention much like @TheYeti with his machine. I was really inspired by his and @Phetishboy's efforts with their units so I'll try to be half as good as theirs turned out to be.
The middle area:
You'll notice the lockbar bolts and nuts invading the wood. 🙄
Started vacuuming things out after removing the ARII, PCB, power brick, control panel, and monitor.
The inside will still need copious amounts of Simple Green and Magic Eraser love. We'll get there eventually.
After removing the glass and cardboard bezels and the monitor, I got an easy win by spraying the cardboard the rich Rustoleum satin blue protective enamel inspired by and shamelessly copying @TheYeti. It really is an awesome color for the bezel.
With that easily out the way, I turned my attention to cleaning parts themselves. The PCB is in good cosmetic shape astoundingly so it'll sit off to the side for a while. ARII also in good cosmetic shape but dirty. Monitor tube and chassis obviously filthy. Power brick awful. It was out the garage for Simple Green and hose down from there for all.
Original G07 looking nice. This cab really is just under 50 pounds of dust and filth.
Additional grime off the chassis. G07 sticker hanging on for dear life.
Glass cleaner reveals more of the Centipede burn. You can almost feel the amount of journeys the titular bug has taken across its phosphor…
ARII and power brick looking presentable, very minimal rust on the power brick! Fuse cover intact and all labels looking clean and shiny still there! No fuses blown, contacts cleaned up, I almost want to keep those fuses, who knows how old they are? 🤣
ARII 1962
Power brick 1962
PCB 1962
Cabinet 1962
👆🏻You love to see it.👆🏻
So it began! I have a newborn only 2 weeks old and a 2 year old so this might take a while. I'm still on paternity leave so I'm taking in the time and enjoying it while I can with the new additions to the collection. So bare with me as I embark on the mission to breathe new life into Centipede cabaret 1962!
Congratulations on both your new arrivals! This project is going to turn out great!
