Centipede blows 20 amp fuse
Check the bridge rectifier under the power brick. Also check the wires going to the 20 amp fuse. If they are discolored and inflexible, then they should be cut back to where they are good and soldered directly to the fuse holder for a better connection.
yes i would agree check the bridge rectifier since that fuse ties directly to it. i have the higher rated bridge rectifier in stock and also the big blue caps also if you need any parts.
https://www.arcadepartsandrepair.com/store/components/atari-big-blue-capacitor-27000uf-25v/
https://www.arcadepartsandrepair.com/store/components/35a-1000v-bridge-rectifier-250-spade/
