centipede AR and power supply testing
mudhens1
chillicothe, Ohio
can these be tested without a pcb being attached to them? i don't want to cook my only working board trying to find out if these are good...thanks
Yes, but in rare instances......the voltage can fail under load.....and it'll probably, definately change a bit with everything hooked up. Check again after everything is hooked up.
Edward
Dokert sells a testing harness. I can load-test them, but you'd have to send them here.
