Centering the image on a WG 4900
whoamonga
Houston, Texas
The image is centered too far over to the right, leaving a blank bar on the left... and none of the adjustments seem to work on it.
The horizontal shift can move the image further to the right, but when turned all the way over, it still doesn't center the image.
The horizontal position lead setting has not made a difference. It either moves it further to the right, or puts it right where it is.
Should I try the horizontal width coil, or is there something else I can look for?
Thanks in advance!
There's a jumper you can use to favor one side or another (big arrow represents it)
If all else fails - and if you're REALLY desperate - there is a way to do it using the centering tabs...
I've tried those jumpers, and they really have no effect at all on the screen's position...
I also have a cap kit laying around that I can use on it, so I'll give that a whirl before I claim myself really desperate.
Thanks!
