Centered Nintendo Particle Board T Molding.
thefader
South Dakota
Can someone tell me if there is a place that sells flat t-molding for the particle board nintendo cabinets? My Nintendo VS is the wider style, but the channel does not look offset. Sorry for another thread on this, but I got confused sorting through pages and pages.
Got it done, hot glue did the trick for the wider groove.
Funny thing is, along the base where T-molding wasn't installed, the groove works great.
Either way, T-Molding.com did me good!
Gamemolding.com. I don't know what all the hubbub is about t-molding.com.
No Hubbub, gamemolding.com doesn't sell 11/16" T-molding which is what I needed specific to this thread. They also don't sell 13/16" which was also in my last order.
Gamemolding.com does appear to be cheaper by $2 per game for the sizes they do have.
Shipping is less and it's Priority which is a plus. Their stuff ended up being $12.56 when t-molding.com ended up costing $20.xx. Gamemolding's stuff seems to be softer, better quality and just brighter.
The orange particle board DK Jr. (Vs. System conversion) cab I have had offset T-molding. The original offset T-molding on my cabinet was not flat. During restoration I filled the groove with bondo and re-routed a centered groove. I found that 5/8" T-molding was close enough, but 11/16" as Teknotoyz mentioned sounds more accurate. Order some samples if you can. Maybe you should get rounded T-molding and say that your cabinet had offset round T-molding ;)
Cheaper is usually good.
I will need to order some for my Wizard of Wor at some point!
