I finally got my unit up and running but there is an existing security code that is locking me out of the adjustments. Is there a way to reset back to original factory settings so I can just use "0000" to get in? Thanks.
Good to see you back, Ken. I don't know the answer to this, but someone posted in another thread about entering 0 and 1 and cycling the power to restore factory settings. Does that reset the passcode too? And in the "I'm just being a wiseass category", I wonder how long it would take to try every number from 0000 through 9999, or does everybody use 1234 for the passcode?
You HOLD DOWN the 1+0 while powering the juke up ( use the slide switch ). Not sure if that restores the passcode. Removing the battery like Ken suggests WILL work.
I appreciate the help. I ended up desoldering/re-installing the battery to get the unit to reset. I did not try the 1 + 0 technique so I can't comment on if that works or not. Removing the battery definitely does the trick! Thanks gain.
