Cart Fury Boot issue
TiltedIllusions
Hello all,
I have a cart fury racer machine that is doing some form of a weird boot loop. I have replaced the PSU and made sure my 5v is pushing 5.05v The system goes through its checks and then it seems to be resetting and doing them over and over again. The screen shows no video signal across the screen. When I first got a hold of the machine it powered on and played for most of a race and then blanked out. Since then it has been stuck. I am attaching a video of the boot sequence on the board. hopefully someone can help me get this great game running again. thanks in advance
  • Boot Video.zip
Voltage measured at PSU and end of Jamma connector. Is there another place I should be measuring at?
Is that voltage measured at the PCB or PS? Also, IIRC this PCB is power hungry...
it's not that it's power hungry, it regulates +5V to +3.3V for CPU power. the SSIO is prone to burning up the +5V contacts on JAMMA edge which will result in significant voltage drops if you don't clean or maintain the edge. I've tried copper tape fixes and it's not as effective as channeling the power supply wiring into the hard drive power plug on the SSIO to give it additional lines for 5 volts and ground in. I might have visual aids from when gamefixer and I modded some Gauntlet Dark Legacies.
