jjhudgins
So you probably asking yourself how can the hell can you be too wide then too narrow.
Now this chassis was a parts chassis acquired from a former OP.
Installed many missing parts.
New caps, pots and Flyback. FB was ticking like in the focus pot area and the occasional spark out the side to the HOT heat sink. Not all the time but occasionally, but when it warmed up, it got louder. It's a orignal white knob. If you guys know me, I do not replace working parts. But I had too here. Obviously it's defective.
I cut it on and I had a good looking image but could not get it wide enough. Lowering c38 to low squished the image. So .22 uf or 224nf was to low. So I put the .39 uf back in.
So what can I do now?
Then I remembered some versions have a 1600 kv installed on the bottom and some are installed where d18 is then they install d18 on the bottom.
I originally put in a 0062 1600V
But the image was blown out. So I installed .0036uf 2000kv
This also had the 4 legged c36 installed
