I have a capcom marvel vs streetfighter board that the 96 pin connectors are bad any idea where to get new ones?
off the top of my head--a parts board.
PM channelmanic, see if he has any.
I am guessing that you are talking about the connectors that are on the "A" board?
They are built up like a stack of three connectors on top of each other to give the type of clearance you need to get above the plastic case. If that is it, you could probably replace your "A" board for less than the cost of the part plus your time to remove the old one and solder the new part in.
If I am correct and it is the connector on the bottom "A" board, I have a spare I can sell you for just $20.00 plus shipping.
Brian.
Are you talking about a whole working board?
I must admit I don't own any Asia boards, but your "B" board is blue and has the same types of connectors that my blue "B" boards do. All signs point to it being a US or European board. If it is, my "A" boards will work for you.
Do you know what game version it would boot to when it was working? Also has it been phoenixed (phoneix versions can change region)?
Brian
It actually does work just some minor graphic glitches, how can I tell what region ? but I'm confused what is different between our boards everything I see looks the same?
