yaggy
Qsound is processed on the CPS2 motherboard... You can output to any amp you want. They stipulate the "Q-Sound" cabinet simply for branding purposes.
I am 99.99% sure of this. I've run a CPS2 on a standard Dynamo cabinet through a standard amp without any issue what so ever and it sounded much nicer than the mono JAMMA output... and in stereo (of course).
EDIT: Here is a Q-Sound amp. As you can see... it's a simple amp. There isn't even an IC on the thing to process anything. It's an amp...
Yes, seeing the board seals the deal, it's just a cheap amplifier. The ones I installed for conversion kits were better quality.
