PsHayes
I'm interested how the wiring works for P3 and P4 if you select a game that has 4 players? This question applies to the cps2 18 in 1 as well as the cps1 14 in 1.
Thanks..
Thanks..
Thanks..
Tusk, when you play HSF2 with OG characters do they have all the sounds? On my board none of the old characters have sounds. Only sounds they have are the hit and block ones.
I had the same problem with my board, that was until IT CRAPPED OUT TODAY! I get nothing but blue screen now regardless of what game I try to select. The menu is still there, but the background is pure blue with no sound.
This just happened to me today, I've owned the board for over a year, used it on and off and occasionally had problems with a green screen on load (had to switch games a few times before something would come up), and then get the CPS2shock exception messages occasionally.
Strangely after the board ran for a bit it usually was OK, but today I couldn't get it up and running for more than a few seconds. Pretty sure it's gone, but if anyone has experience with these kinds of problems with these boards I'd be interested in reviving it.
Just got the 18 in 1 board so...how do I connect it to my existing cab? (sorry for the newbie question, but this my first mod) I assume the jamma harness connects on top of the OSD board? So should I pull out the key to make it fit?
yea i was getting wierd green colors but i think sum wire were touching ground or sumthing cuz i moved sum wires around and it fixed it but wait my board works good except the the street fighter 2 aniversay every time i choose it takes me to giga war or watever its called
My board has developed an issue (or always had it and I just never noticed). I can't coin-up Aliens vs Preditor. It will load up, but it won't coin up... and it doesn't have a FREEPLAY mode...
Strange....
Try the coin chute settings...
And/or reset shit.
