NoAffinity
- Joined
- Oct 25, 2005
- Messages
- 1,370
- Reaction score
- 92
Capcom CPS-1 "Stereo" Sound from CN5 Connector
Some of you may enjoy this. I saw an old post on Neo Geo forums saying "just connect via CN5 and you get stereo sound from your CPS1 A board", not much more information. I saw a couple other posts across other forums (including here) ranging from "I'm working on this thing, which I saw at Neo Geo forums" but no follow-up confirming success or failure, and another thread "I made this adapter for CN5 output but the sound is garbage".
Well, I made an adapter for CN5, and sure enough, the sound was garbage. Right channel louder than left, but overall audibility very low with an external amp turned all the way up.
So, I stared at the CPS1 motherboard schematic for a while, and it sure looks like the intent is there to provide 2 channel sound via CN5. Well, the key is removing VR1. Alternatively, you may be able to put a simple on/off switch in line ahead of VR1. I haven't tested that yet, though.
1) Make an adapter from a PC case fan plug spliced to a stereo 3.5mm connector (or other suitable stereo connector)
2) Connect adapter to game board and to an amp. I hooked it up to my Q-sound amp, and used this Radio Shack volume control adapter, with 3.5mm in and 3.5mm out. If you are hooking up to an amp that has volume control on it, then you obviously don't need something like this.
3) Enjoy "stereo" sound from CPS1 games that support it.
Note that once VR1 is removed, you will not get audio through the JAMMA connector. So, it's either JAMMA mono or CN5 "stereo", but not both simultaneously. If someone can stare at the CPS1 A board schematic longer than I did and see a way to have both going simultaneously, please post.
I went ahead and captured some direct feed of GNG and SF2 HF. Below is the supported game list. GNG is not on there, so it was a good test.
My assessment: GNG has slightly lower audio on the right channel. Possibly non-supported games are actually at a disadvantage using CN5 output. SF2 HF splits the FM sounds across the channels – instruments are on the left channel, percussion is on the right. Non-FM sounds play through both channels. The splitting is most noticeable during Ken's ending, when the wedding song starts playing. Also, possibly richer bass tones for SF2 HF.
GNG direct feed capture: https://youtu.be/ojk19Lo-oKg
SF2 HF direct feed capture: https://youtu.be/1vMTSlAtNg4
Supported game list. I thought I saw a longer list just a couple days ago on a different forum, but couldn't find it again. If somebody finds it, please copy and paste.
http://www.neo-geo.com/forums/showt...m-CPS-1-boards&p=133483&viewfull=1#post133483
1941
Adventure Quiz Capcom World
Adventure Quiz Capcom World 2
Street Fighter II (also CE, etc.)
Strider
UN Squadron
Captain Commando
Enjoy!
1941
Strider
UN Squadron
Captain Commando
Enjoy!
