Yeah... it finally happened to me... I'm having a serious problem with my Capcom 18-in-1...
Let me explain exactly what happened.
I was playing... I turned off the machine... I pulled the machine out from the wall and turned it 90' degrees. I removed the back door. I plugged the machine in to do some monitor adjustments and...
The menu appears... but that is all. Gigawing does not play... if I coin up the menu and select a different game... nothing changes... I get what appears to be a quick reset and ... nothing. ARGH!
Voltages are OK
I re-seated all socketed chips... no help
I removed and re-seated the A/B boards... no help
I moved the voltages up and down from 4.95 to 5.11 and no help.
I did nothing to the board to cause the issue. Moving the cabinet was no biggie...it's on nylon feet and slid very easy.
WTF happened? I know it's not the cab... the damn menu appears and works fine (I can move up and down and make selections, etc)... jut the CPSII hardware isn't working.
Two LED's come up on the top-most board of the stack... and the LED on the board between the CPS2 stack and the jamma harness comes up.
Help! I had this bastard sold for $800... I was making the adjustments for the customer... SHIT!
EDIT: And one time I selected a game, it reset ... nothing came up but the damn coin counter went crazy.
Voltages are OK
