I've read that it is o.k. to use a higher voltage when replacing caps as long as the uf value is correct. My question is whether any voltage is ok, for instance if it should be a 16 volt I'm sure it's ok to use a 25v but is it also ok to use a 200v or higher?
Also is there any instance when you should NOT use a higher voltage?
