kiphartzell
For those of you who are component marking experts.....
I need to replace a mylar cap that has one leg broken on a Asteroids board (location C69). The manual calls for a .1 uf, 10% 100v mylar capacitor and the original caps (4 of them) on the board have the following markings ".1K 50/100". I assume the .1 is in microfarads?!?, K=10% and what does 50/100 mean (100 maybe max volts, but what about 50)?
The question I really have is are the following two also .1uf caps?
This one I just received from Bob Roberts as a .1uf cap (K=10%, 100v) marked "100K 100v" <- this almost seems incorrect.
And a second one that I just dug up which uses the IEC code and should also be a .1uf cap (K=10%,max=100v) marked "104K 100v".
Please educate me, Thanks.
