What is the best method for cleaning the gunk off PCBs before doing a cap kit?
what should I use contact cleaner,alcohol,or fingernail polish w/acetone on the contacts?you can also just carefully slide a good handled flat blade in unhook the anode then discharge the tube
but if you dont want to work it hot do Jimjaycee's method
i also find that finger nail remover (with acetone) works good cleaning junk off of contacts, trace pads.
replace the caps one at a time and verify polarity before and after (as well as value), test the caps you pulled at the end to see if there were any out of range
Have put 7000's g07's and a 4900 in the dish washer then cap kit and no problems yet
On a 25yr old double layer PC board you may want to use solder wick before a solder sucker. I've found that the suckers can damage the traces far quicker than using wick alone.
Not sure if Rat shack sells wick or not.
Michael
I've tried two of those radio shack solder suckers, and couldn't get either of them to work
Those Radio Shack solder suckers are junk. This one is way better http://www.mcmelectronics.com/product/21-4699
Matt
I use mine all the time. only time it sucks (well, not literally) is if the solder joint has a very large pin in it that the tip can't get around
I always mention that you shouldn't pay attention to the wizards here that do cap kits all the time when they tell you cap kits only take 30 minutes. maybe on the old dinosaur monitors they run, but when you get into the newer stuff that's got around 32-34 caps to change out, it'll take awhile.
Should I always pull monitor doing cap kit?
A pair of Snap On flush cuts are well worth the $$$ .
I always mention that you shouldn't pay attention to the wizards here that do cap kits all the time when they tell you cap kits only take 30 minutes. maybe on the old dinosaur monitors they run, but when you get into the newer stuff that's got around 32-34 caps to change out, it'll take awhile.![]()
Wizards, huh? There's no reason why one cap can't be pulled and replaced in one minute or less.
My biggest problem with the Radio Shack suckers is that they dont create enough suction. I dont even have to fully apply my Soldapullt sucker to the joint, I just keep it a hair away, melt the solder with my iron and press the button. I do this without removing the iron from the board. Makes for a really clean hole. I've done it this way for 20+ years and have gone through maybe 2 tips and 3 suckers.
Matt
I think there is a quality control issue on these things. Now on to finding my old one.
I"m just gonna chime in here and start some trouble
The whole "don't discharge a vector monitor with a screwdriver" thing is a bunch of bullshit. It's an urban legend.
I don't know how all that got started, but tons of people have said it's b.s. and I believe them. Zap away! Ask Bob Roberts about it![]()
