I put a new light fixture in my lethal enforcers game & it wont light up so i took a known working one out of my other game & nothing on that one. it is a brand new fixture any ideas on where to look is there a fuse or something?
So you are saying that the new fixture doesn't light up in the lethal enforcers cab, and a known working light doesn't light up in the same lethal enforcers cab?
Do you have anypics of how you are trying to wire it up?
A flourescent light fixture is pretty simple. Run to power wires to the light and flip the switch on.
Maybe a wire has come loose that is going to your fixture is all I can figure.
I belive its 120volt there's a black & white wire going to the light which i hooked up to the same color wires on the new light.I did this on my other game & it lit right up. the wires come out of the power supply they did go into a switch if the cabnit was open it would shut the game off that switch never worked so i thought that was it so i took that out of the lope,still nothing.
You need to check for Voltage at the black and white wires. Petty straight forward. If there is no Voltage (120VAC) then you have a blown fuse or a bad connection. Also, I believe on Lethal Enforcers cabs there is a switch on the top as well.
